steviec_lj
Rust Welding Professional
- Barnetby, N.Lincs
Did some redneck sewing today..
The joys of pulling a curtainsider and scrotes of the night. Oh how I missed curtainsiders..NOT
Nice!more exotica ,note how the stops are staggered , the sodium lighting is Jabberwocky ffor photos
amperage was around 160
max interpass 100c so needs air cooling after every pass takes around 12 hrs welding, lots of gas, purge is argon 2%nitrogen
torch high purity argon ,
machine is Kemppi mls 3000 watercooled
with knuckle head torch
ndt is ,xray ,dye pen and camera internaly
so theres no skimping on quality View attachment 195392
What’s the material?heres a 3 inch sch40 fixed position View attachment 195406
You'd be welcome mate, but there's not a lot left
How it went that quick i dont know !
I’d love to catch them in the act, bodge tape and cable ties would be deployed and they’d get to experience long distance strapped to the trailer.
I was going to suggest taking them a few hundred miles away
It happens way more often than what you think...I think one day we'll realize @Memmeddu has stopped posting because he's blown himself to bits!![]()
I was going to suggest taking them a few hundred miles away and putting them off in the middle of nowhere, but they'd just steal someone's car to get back home.![]()
Not if cabled tied or glued to a tree.
I would say nailed, but think of the noise.
Would have a better effect strapped to the radiator grill, like a kiddies toy on a garbage operative’s van.![]()
incidentally, there’s a video out there somewhere of a UK driver taking 4 stowaways on a minor 400km detour AWAY from Calais I believe they plead him to stop the entire journey![]()
I helped to make green flames.
With help from here.
View attachment 195490 View attachment 195491
I supplied the workshop, @Chillitt the parts, 2 80+year olds the labour.
Made this inductor for the welder
I used 2 microwave oven transformer cores and I welded them together leaving a 3mm air gap between them preventing the magnetic saturation of the core
Wound 10 turns of 16mm² welding cable
The input side has an 80cm pigtail cable
The output side ends in a panel dinse connector .
All this mounted into an inverter welder housing that I got outside year taking rain waiting for a project
All this made out of scraps
I have to make better connections but I can't now because I need some materials
So the purpose of this thing is give hot start and some sort of arc force to my inverter welder that doesn't have both of those capabilities .
My welder alone can run E6010 no problems but only after struggling to get the arc going
But with this things now it can start E6010 instantaneously and kept a longer arc
The weld you can see in the picture is made using a 3.2mm E6010 citoflex rod and 100A straight drag no manipulation
Without this "attachment" my welder has to give 150A and again struggle a little bit to get the arc going
Now it's way easier to run this rods I just need to practicing with more.
The arc is violent seems like welding using 200A big hudge arc and a big red flame coming out of the tip of the rod
I'm very happy
I practically grown up watching him since was in Honda , when I was maybe 3 years old.
