I have a small woodland that saddly has been used as a tip over the years. Was going to take it all to the tip till we found out its going to cost £80 per ton & as all the rubbish is in the ditches its also mixed with soil. So after some head scratching I though about making a stone / riddle bucket as new ones cost over £400.
To give you some idea of the problem here is a pic
Well I have decided to try a stone / riddle bucket on the digger to get the bulk of it out. I have a bucket I dont use & it also had a few stress cracks so I have ground them & welded both sides up too. As most of this was thick stuff I have run a root weld first & then a much bigger wider cap.
Now I know that this is not in the legue of the pro bucket repairs but as its only used by me & wont ever be further than 100m from the welder & its for one job only it should last.
THE BUCKET
First cut using 3mm cutting disk (was on the grinder
Did the rest with 1mm disks as its easier
THE HOLE
& the disk used
All the parts bent & laid out. 16mm square for the bars & 6mm x 50mm for replacing the strength removed with the hole.
Some welds & reverse sides showing heat
Just a few more bars to weld on & its done
Will weld the last few bits up tomorrow & then test it.
Justme
THE BUCKET
THE HOLE
& the disk used
Justme
I hope the riddle bucket works well!
