Hi everyone!
I'm new to the forum, and wondered if you guys can help me with a problem that arose today.
My SIP was working fine and has been no problem at all. Then all of a sudden, I pick up the torch to continue and.....nothing!
There's power..the fan still runs. The motor that drives the wire feed is ok because I disconnected it and tested it independantly. When I pull the trigger it does not start the motor. When I took off the cover, I can see the contact in the little clear plastic switch contact thing, opening and closing (well going up and down!), so I assume the trigger is making contact ok, but the drive does not kick in as normal.
Can anyone help me please? Can I buy replacement parts, or is it a throw away job?
Thanks in advance guys
, so I'm praying I can fix it!
That one has popped up on here before a couple of times - I think it might have been Weldequip who was the first to suggest it as a fix. Baffling if you don't know they do that.
. Just recently found myself some nice spacey storage so picking up the baton again at long last!
