Adam Marshall
- Nottinghamshire England
Does anyone have one of the lincoln invertec 350 power source? Do these run on single phase?
They said the same for the cutmaster 52 but after researching about is three phase onlyFrom the brochure it looks like it can run virtually on any power source from 208v all the way to 575 v! Its also not de-rated for 220-240 so it can run full 475 A from that ! Impressive specs although its lacking HF start for tig welding but features a soft start lift tig for less contamination of the tungsten electrode !
Probably no more than 250-300 Amps... it takes a lot of juice to get that thing going full chat !How many amps do you think you would get from a 32 amp supply with this could with a lincoln wire feed
I think so too...3 phase power to get the full power...They said the same for the cutmaster 52 but after researching about is three phase only
Generally three phase inverter machines can't be powered in single phaseI think so too...3 phase power to get the full power...
If you look at the name plate on the back it shall give you all the details, you have to also flick a switch at the back from 380+ volts to 230 volts, you also do away (isolate) with one wire in your input cable (the black one) and wire up the remaining three to single phase...Does anyone have one of the lincoln invertec 350 power source? Do these run on single phase?
