eLuSiVeMiTe
Did debate a pair of these before matth offered me a wheel that was a perfect fit.
Exactly what I do on my flypress when the works too big for the hole.Another consideration. A couple of appropriately thick steel bars ( like parallels ) could also be used across the press slot, and adjusted to any width desired.
Been there many times, the sudden moment of realisation that your cunning plan has a fatal flaw
Now I don’t have any more suitable sized stock,
What size are you working with? I have a few bits of thick stuff rescued from my favourite skip.
I have a 6" disk at about an inch thick here
Trade ya for some bar
Will 9mm do.Hi John
I need a finish size about 100mm square and 10 or 12mm thick
Will 9mm do.
Have some flat bar I cut off some structural steel a few years back. About 6" square
Wife is. Il just see if I can find em and pop you an address.probably, I need to be honest with this little project. In all reality once this is done it almost certainly wont see th light of day again, just like the rest of the stuff (junk) ive got.
Are you around tomorrow ?
PM me your address
Scratch that. Not where I thought they were. Sure I had 4 and used two.Wife is. Il just see if I can find em and pop you an address.
Will have a proper poke around when I get home tomorrow mate
@Parm Too wet & miserable today to dig in the bags outside where the odd stuff hides - hopefully tomorrow will be better, if the forecast is to be believed.
@slim_boy_fat
Isn't that normal for this time of year?
