Craig-SM
- Heckmondwike
So I did damage the bottom boot but they're really cheap so nevermind,
But I'm not sure the joint is even any good, should there be abit of resistance when moving it with no boot or grease? Seems quite loose but there's no play in the ball up and down
The play I had was side to side, up and down there was nothing, hence thinking wheel bearing is gone, can't really check the bearing with the hub off.
Yep, that's knackered.
The Draper ball joint separatorI linked to is good. It's been hammered into plenty of ball joints and the bolt done up to the point were I thought it would strip the thread but it carried on working until the ball joint gave up with an almighty bang.
