This is what it should look like.
The cable has to fully fill the lug before crimping, if it doesn't that means the cable is the wrong size for the lug.
I just checked the right size cable against the lug and there isn't a mm of space left.
Die`s virtually touch.
Dont for get the hellerman stretch sleeves
View attachment 190804 View attachment 190805
And the Hellerine lubricant to aid fitting the sleeves
Toolstation or screwfixNever heard of those hellerman things I was planning on using regular heat shrink?
Part of the problem my be the lugs I am using; can anyone recommend a reliable supplier? I would benefit from 10mm squared and 25mm squared. Have some on order, but there more the same of what I've been trying.
Thanks.
Regular heat shrink is fine if you have it.Never heard of those hellerman things I was planning on using regular heat shrink?
Thanks.
Didn't know if the likes of Toolstation would handle the amps; although suppose you could easily say the same about anything bought off of Ebay. Happy to be a fan of Toolstation and have one locally; so I'd consider that a win.
Thanks.
I have found that crimp terminals can vary considerably in their specified size, especially those purchased cheap off ebay. Quality brands seem to be more accurate.
Likewise there is a lot of Chinese special cable which is nowhere near the size printed on the jacket.
As has been suggested choose the one that just barely fits over the wire and don't worry too much about the numbers.
With the hex crimps you want to see a nice defined hexagonal crimp mark, if there is any "flashing" sticking out the die size is too small, if you don't see defined "points" on your crimp the die is too big.
