It would have been just as quick for you to do a search on google to get the answer.
But as I'm bored with nothing else better to do and feeling generous with my time...............
A quick Google suggests the following
They come in 250 amp flavour and 325 amp flavour depending upon the size of cable used
Here's the link
https://weldingdirect.com/connectors.html
...I don't use the Google Search engine and sometimes mine returns sparse results...
Have you considered using the Google Search engine?![]()
Thank you; I did have a look, but I don't use the Google Search engine and sometimes mine returns sparse results... I even checked the Dinse catalogue thing from manufacture website, full of pretty pictures but doesn't list amps.
Appreciate the help.
I don't get the same results, probably because I'm using a browser plugin for search engine, doesn't matter now though :-)
Why do you use DuckDuckGo if you know Google often gives better results? That's the weird private one that stops you getting tracked isn't it? Only know it from playing with Tor.![]()
Ahh that's just scaremongering!
I hope.![]()
Quite a bizarre conversation so far !
So why did you need to know the amps rating of the dense connector anyway ?
After building another return lead with a Dinse connection, but I'm after something higher rated than the 10/25 I have atm, so I have more scope for using the magnetic return clamp I got from a forum member. Wanted to check a 50mm cable with 35/50 would be rated enough to get the most out of the clamp so I can use it on higher rated machines when the opportunity comes up.
Seems like it should work well.
What's wrong with 50mm cable; I'd rather be over spec'd than under spec'd.
