Tungsten Grinding - Bench Grinder
Ok i took some macro photos of my 1.6mm Ceriated tungsten. It looks that the perimeters edge of the pointed nose is chipped-jagged. Does this affect Arcs performance ?
I used 80 grit band. And it looks like that i have to use much finer grit.
EDIT. It looks like i have to point the nose to absolute point and then grind my flat ! How do you grind your tungsten ? IS there a problem if i use a stone that has grind some other material on it ? (in theory there is problem, but anyone to verify it in practice ?)
