Im always in the sh1t one way or another
Me too, it’s just the depth that varies
.Im always in the sh1t one way or another
.*starts putting sticks down the drain...*My drains block regularly...well a few years in between....last twice Ive rung Severn Trent and they come out, clear them out and later I get a cheque for £75 as an apology
Update been round my mates after a douse of drain cleaner add we got the rods down the bend and pumping with water got the drain clean
Thanks for all the help
] like this stuff if not maintained regularly
i realy need a set of thiner rods the big normal ones wont bend round the 90 degree bend
At my old house we got blocked drains all the time and i used a pigs tail screw and had another run of rods with a jet was line tapped on, When we moved i put in all new plastic drains with rodding points and set it up so we could flush the drains right to the manhole which is 7 feet down at the edge of the property, never had a problem in 20 years.
, with hindsight I should have slipped in another manhole or a rodding point half way . But it hasn't blocked in the 11 years it's been done.Have you tried to push the rubber drain cleaning disc through yet ? Count the number of rods before you do just in case it sticks because of " flowspar " at a bad pipe joint , that way you'll know where th problem block might be . .no to be honest we are a bit worried we have done this 3 times in the last 3 years
he had a tree there but was taken away last year what he hopes will sort the problem ive said to put gutter gardes in there to stop the carp getting in there
but there was no big bang or glug just pumping water pumping water and in the end it let go thats why we are not sure its fixed i still thing there is something down there but the slit is gone thats letting the the water through
