davidjohnperry
a different breed
- yate/bristol
We have angles welded stagard each side for that purpose plus it's thick and we fabricated ours to the correct length by gas cutting them and putting the end plates on
A lot of work involved setting that track up exactly in line with the joint.https://www.westermans.com/gullco-gk171-90-straight-line-welder-for-longitudinal-seams.aspx
Something like this I would buy for myself and sit there earning money browsing Mig welding forum...
What's the price difference out of curiosity?A lot of work involved setting that track up exactly in line with the joint.
Ours you just throw it up on the wonk and let the tactile seam sensor take care of the rest![]()
Depends.What's the price difference out of curiosity?
Excellent method to track the joint. Looks a doddle to set up.
You can get that tracking sensor with a ball on the end to for filling up a V grove. The only time it’s not going to work is capping off because it needs minimum 1 edge on the X axis to follow. Fillets and laps and even outside corners all day long.Excellent method to track the joint. Looks a doddle to set up.
Get your batteries and chargers from screwfix and you could bring that down a lump.About £15k if I remember correctly.
Yeah that was ridiculous lol.Get your batteries and chargers from screwfix and you could bring that down a lump.
Have you ever seen long 7024 iron powder rods burn using a gravity feeder (sometimes called a Ski).....we used to make rods from 600-900mm long....very easy and simple set up......one shipyard used to burn 24 at once on a beam.....doing egg box type deck plates......I cant find anyy photos
sounds like it.......I remember seeing some litriture with a tripod type arrangement burning some big long rods. Would that be a similar setup ?
