these are all things you use your imagination to overcome I suppose.I do. I've yet to see a centre with a tang. I did manage to drill the back of my live centre and fit a slug but very often fixed centres are hardened right through. That aside, holding them whilst you drill makes for an interesting little problem.
You can get a MT2 hand reamer, just to clean up any burrs.
Are you doing much tonight? I'll pop over and grab that Rotator if not and can take a look.
Hows 16:00? I'm figuring i might miss the traffic that way
Inches, mm, it doesn't matter.
T Interestingly centres do not seem to have tangs. I have never understood why. I usually pop a small brass slug in before inserting the centre, or else it's the Devil's own job to get the damned thing out.
For my running centre I glued an old ball bearing into the end of mine to allow it to eject, big enough to press on the taper side and not be pushed into it.
Yeah basically.so on my scale on the dial it is 0.1-0.9
0.1-0.2 is 0.25mm?
 well i aint sure about that! not when I measure in metric
 well i aint sure about that! not when I measure in metricso on my scale on the dial it is 0.1-0.9
0.1-0.2 is 0.25mm?
it does when it needs to be accurate
