Hi, guys/gals
I have inherited a SIP Ideal 240 which hasn't been used for atleast 4 years, it has had about 2 rolls of 15kg wire through it ever, so there should be plenty of life still in her one would think. Manufactured 1993.
I have been sifting through the forums and tried pretty much all the suggestions to do with this problem. So, here's the situation...
flicked all the switches to ensure they were not the culprits (all is good with those), they are dial switches not push-in so I would think they would have a better contact anyway
Relay clicks when trigger pressed (have cleaned relay contacts with contact cleaner, they came up shiny, not scuffs or anything).
Pulled swan neck appart, red/white wire contacts clean and tight (although there was a blue wire which runs up the lead but dead-ends in the handle???)
Successfully ran wire feed motor on 12v battery (so thats ok).
No current detected on metre when trigger pressed and probes on where the wire feed motor is powered from.
PCB looks ok, no, blackness anywhere, no funny smells, Checked wire feed pot (1ohm 10KA) when pot was fully on, got reading of 1.5 ohms, as soon as I knocked it down the meter overloaded (set on 200 ohms). I would say pot is shagged? But wouldnt it still output something when I set the pot as high as it would go?
We do you guys reckon, is it the pot, or is there somewhere else I should be lookin?
Any helps a help.
Gordon
Any helps a help.
Gordon
