HughF
- Work: Dorchester, Workshop: Corfe Castle, Wife's place: Frome
I have been having a workshop cleanup/sell off these last few weeks and have sold my water cooled 300a Tig. I’ve replaced it with a 200a machine and in the process have lost my water cooler.
This thread is mainly to document the build of a replacement cooler. I’ve decided that it should be compact (I would like it to fit underneath the welder) , and built from the cheapest parts I can find that will do the job because I’m tighter than a ducks....
I’ve been looking around for a used procon micro-vane pump, the ones that are powered from a brushless permanent magnet motor, but they don’t seem to be on eBay anymore for £49... as such I’ve decided to try a 230v shower booster pump.
Exhibit A:
This will be with me early next week, along with a new wp20. I’ll run some tests and see if it is any good, if not eBay returns can take care of it for me.
For a radiator I decided to go with a cpu cooler, again cheap junk from China - because if it works, it works....
Exhibit B:
I have a bunch of 120mm 230v fans, just need to make a suitable reservoir from aluminium sheet and box it all up. I might do something clever with a current sensor and a time delay relay so it fires up on arc strike and stays running for 3 mins after the arc has extinguished. My new welder has proper fan on demand and is usually silent in use, it would be nice to keep the cooler quiet when not required.
Anyway, I’ll update this thread as I get the parts delivered and tested.
Exhibit A:
Exhibit B:
