brightspark
- yarm stockton on tees
was a bit choked off no radio all week on van
just checked the yellow wire supply to it and no power . pulled all the fuses out and there all ok . I thought it may be the ignition key switch at first . great stuff cant be a ssed with that
just googled it radio not working and it came up no power to yellow feed cable
it said check hidden fuse next to battery on the lead it may be corroded only fitted on the diesel model . sure enough its corroded . sprayed it with wd 40 new fuse and works a treat
https://www.corsa-c.co.uk/forum/showthread.php?209720-Hidden-Fuse-Diesels-Only WHY DO THEY DO IT
good old google everyone can be an expert and save time and a fortune
