daedalusminos
- Norwich
Looking at the joints I can see, and the types used, seems that they all rely heavily on the glue strength, with little mechanical strength / resistance designed in. OK, agreed modern glues are strong, some stronger than the wood itself, but given the relatively small surface areas compared to the potential forces excerted, I'm not convinced.I can appreciate it's well made, and that it looks good, but from a practicality perspectiveLooking at the joints I can see, and the types used, seems that they all rely heavily on the glue strength, with little mechanical strength / resistance designed in. OK, agreed modern glues are strong, some stronger than the wood itself, but given the relatively small surface areas compared to the potential forces excerted, I'm not convinced.
As an example look at the rear wheel triangulation, just a wee shoulder and a glued joint, the rest is glue strength, might be ok in pure compression, but add in any twisting loads, and how long before that failed... maybe as keith 66 says, they've built in hidden reinforcements / strength added to the joints that we can't see, and maybe I'm being a bit harsh, but for me that would look good on a living room wall, or such like, but on the road, I wouldn't trust it much, irrespective of price...
still a thing of beauty for all that... but just another example of - why? because we can, not because we need...
..... Wooden bikes have been done before and they perform terribly but look nice. .
And 6’ diameter wooden propellers that span at 800 rpm.......
I'd be interested to see how it holds up, but looking at the work he's done on it I reckon he's put more thought into it than the 5 minutes it took you to type this post.
so have I
it was the casting patterns for a real one
Speaking of bamboo.
My thoughts too. That's why I would be interested in more info on construction. Got a be more going on that we can't see.I would be interested to see how it would stand up as well, and I'm sure he has given it more thought than my 5 minutes worth, as the designer / constructor would be responsible if it failed.. Like I said, there maybe more to the joints in terms of reinforcement that we can't see. Just some of them look pretty weak to me from a mechanical engineering viewpoint, considering loadings and joint concept, especially considering if it was my 19 stone bouncing on it over pot holes etc.. At the end of the day, we're judging something without the full details, so it can only ever be an unqualified opinion, same as everyone elses.. I would be interested to see the joint construction in more detail though.
still beautifully made though, no question.
