an acid flux is best on steel![]()
Ronan I use everflux, never fails. https://www.bes.co.uk/everflux-sold...MI6tS2hZq34gIV5zXTCh29DgcAEAAYASAAEgI2b_D_BwE
bob
Will that work with steel though Bob ?
Yes Ronan I use it on everything, clean all surfaces , completely cover surfaces to be soldered with flux, go very gentle with the heat or it will burn , feed in the solder and don't forget to wash off everything thoroughly when finished . Its my go to flux when steel brackets become detached on brass radiators
Bob
Smashing, i'll get some of that then.
Here you go Ronan a real life demo
A nice bit of "cured" 30mmx3mm flat.
Cut , prepped and fluxed
Keep the gap tight to aid capillary
Soldered and bend test
View attachment 180086 View attachment 180087
Can you tell there`s nothing on the telly
Bob
yep its the best for stainless steel as well rub it in with wire woolHave always used Bakers Soldering Fluid - do they still make it ???
