pressbrake1
- Essex
Even though the original are silly money and supplied as OEM for the widow sample rig they are badly modified and fail
Note customer was too cheap to let me make a new shaft
I have an identical one in the garden I sharpen my knives on ,so will look for a name and tell you.A busy weekend.
This lovely hand cranked wet stone, it was a nice simple restoration.
A quick silver solder job on one bracket.
The reservoir was heavily covered in lime scale, the paint was hiding a lot of rust.
A good descale, Tesco own kettle de-scaler and almost followed the instructions. Followed by a dip in hot caustic soda and finally a over night soak in citric acid. The finish you see is after a brush with a scotch-brite pad.
The reservoir is sealed with a rubber based paint, then the normal under coat and top coat to finish. There is a makers mark, but it is too worn to get any details.
The handle was cleaned up in a lathe and dipped into bee's wax.
The stone is a fine grit and has been dressed square. By the simple act off using a power drill in place of the handle and a dressing tool.
View attachment 179532 View attachment 179534 View attachment 179536 View attachment 179538 Made new housing for diamond core drill
It goes on a ground investigation window sampler called a terrierIs that for a trailer rig? Looks like it mounts to something with a 2-leg post.
View attachment 179625 View attachment 179626 View attachment 179627 View attachment 179628 View attachment 179629 More progress today,ground the surface for keying the galvafroid,then repousse ( beating) to give the effect of body armour and add to the depth features,mounted Owain complete with shield and stirrup.
Here’s mine,only had it about 6 years.A busy weekend.
View attachment 179816 View attachment 179817 View attachment 179818 View attachment 179820 View attachment 179822 View attachment 179824 Not made today,but last December,as they’re now top coated I’ve photographed them,I used 30 solid square,50/12 convex,with a 16 square stiffening underneath,all galvanised,then resined into stone.
Probably the wrong place for this as no metal was formed in the making of this but...
