owas
- Birmingham
What paperwork? You should tell the insurance (although mine stated that only performance enhaning mods need to be declared) but not sure what else??
My 200tdi has done about 100k on mixes of some SVO to diesel up to 100% SVO from this point in the year onwards (because it is warm). I had the head off about 18 months ago to do a head gasket and the cylinders still looked perfect - no signs of gummed rings or anything amiss. Your 300tdi will be fine - same FIP as mine and it will handle it fine. I keep thinking about twin tanking and have everything other than the tank (Pollack 6 port changover valve, het exchanger and heated filter), but it runs so well in the warmer weather by just chucking it in the tank that I see no need to install the extra gear.
I think that might be an extreme case?
I'll pick some up on the way home,
I do have a spare pump so it's not the end of the world if anything happens
300tdi
70p/litre is good
