Spot weld bit
is there a better type of drill bit than a standard 8-10mm jobber to remove 4.8mm pop rivets?
5mm bit, take the “flange” off, punch the rest through.
That way, you can put rivets back in should you want to
i want to avoid damaging the sheets as much as possible.
ive looked on the other thread about spot weld bits - theyre like miniature hole saws?
That's the way I do it but I get really ticked at the heads of the rivets getting stuck on the drill and having to keep pick up pliers to pull them off
