Pete.
- Kent, UK
Did a bit of work on my gear hobber.
First was a belt guard for the cutting oil pump. This is driven off the main motor and is a gear pump that sends oil from the reservoir up to the hob which then drains back down from the tray into the reservoir. It's about 60 or 70 years old and tends to leak a bit which causes the belt to fire oil all over the floor/your legs and feet. I got fed up with this so I bashed out a rough and ready belt guard from some scrap ally sheet. Oil now drips into the tin instead of flinging all over the floor.
Next was a pressure relief valve for the oil pump. There's a tap at the end of the pipe but you can't turn it off because the pressure goes though the roof and stretches the bolts holding the pump together, and stalls the motor. I stuck a tee in the oil line and knocked up a ball-and-spring relief valve which just dumps into the tray. Now you can adjust the oil flow (or turn it off completely) and it never bothers the pump.
Finally I made an over-sized cutter guard because the original didn't quite fit over the largest of the hobs. I just knocked it up from a bit of old stainless tube, welded a stub on it for the cutting fluid feed then drilled through the feed tube to make a port for the oil. It works great but I got the feed hole very slightly low. Doesn't matter because the larger hobs tend to also be longer so the oil gets to where it's supposed to be as you can see in the pic. Here I'm cutting a 16DP gear for someone's lathe gearbox.
