Badger1bear
If your not on fire, then your too far away
- kent
Its a start I suppose![]()
I could use the dimmer switch in the front room and improvise mig tig and arc intensity LOL
Will save you getting stuck into the badger beer, then again you may be so disappointed with it that you will end up drinking your weekly supply.I would have to go down to the cellar and if I do that it will end up a late night![]()
He doesn’t weld silly.What's wrong with just using a welder?
it’s only money, it just happens that I have some spare
I’m just taking the Micky BB hence the smileysI guess your still going on about the the brand new esab rebel which I traded up to Hypertherm 45xp and the tig welder I brought round to you that I couldn’t get on with.
Things change manit’s only money, it just happens that I have some spare
Is it in warranty shox?
One thing that was an awesome experience from optrel was using the warranty service when mine cracked.
I was sent an email with a quick form to fill out asking the details around the fault and the serial number. Took 5 mins to fill out and send back. 48 hrs later a brand new one landed on the door. They didn’t even want the old one back or quibble the reason around the fault in any way.
Perfect quick easy system.
Probably because the fault isn’t something you can attach in a photograph.Well I had to send it off.
Hopefully back next week
In my case I was able to catch both the crack and the helmet serial number in the same photo which no body can argue with is a clear fault with a new mask. That’s probably why they just sent me another one.
