fixerupper
- Crete Greece
So I have a Komatsu brush cutter a BC3500DWM…and Its about 14 years old done a fare amount of work I pulled it out of the shed the other day to whizz over the bit of land behind our house , fresh fuel , new plug, new air filter …first pull starts up fine but it feels gutless, and slow, even grass laughs at it ….I’m thinking dirt in the carb …before I pull it to bits ..does that sound right ..the drive down to the business end seems ok and free and the gear case rotates freely, it fires up so I’m guessing the piston and cylinder is OK …what else can explain the problem …here is a photo …I took the air filter off to get a better look …the foam air filter was damp with two stroke ..is this normal ? there does not seem to be any adjustment on the carb apart from the cable stop screw ...am I missing something ?...I'm learning more about small two strokes ..than I ever wanted to know ....
