slim_boy_fat
- Scottish Highlands
Another of those annoying little jobs off the list
I have a few more if you want some.![]()
What I’m saying is scraping is really really easy and much easier than filing to close limit and there’s nothing wrong getting rid of tight spots or cosmetic stuff but it’s forgetting what scraping is forI would not ever dream of trying to gain-say a time served rebuilder but here's my take on it:
I agree that cosmetic scraping holds no value but if a person removes the rock from a cross-slide by scraping the ways in flat, and then finds that it's pointing in the wrong direction, then it had already worn to be pointing in the wrong direction so they have lost nothing in that respect but gained very much in terms of rigidity and it's a fairly simple matter to re-scrape something like cross-slide alignment into truth following a facing cut. Whenever I'm holding someone's hand in basic scraping instruction I take great pains to point out and demonstrate the areas of typical wear so that they avoid scraping those further. At the end of the day you have to commend the efforts of anyone who is at least willing to give it a bash especially if they are hindered by limited skill and very limited tooling/reference pieces. I got into it because try as I might I could not find anyone to do scraping work for me.
What REALLY gets my heckles up is people (dealers, mostly) who take a flaker to make a way look like it's been scraped in just so they can dupe more money out of an unsuspecting buyer. That's just dishonest IMO.
I made a mess. Damn useless chuck won't come off, even tried the impact driver trick. I'm disassembling it so I can get a better grip on the chuck and not injure the gearbox and also apply some heat on the thread.
I got stopped by lack of a suitable lock ring plier though, but I will get one. Put the gear box back together so I don't forget how, though the photos above help to reassemble.
From what I can tell online there is a 1/2x20 UNF thread inside. Yet when I asked makita service if a Röhm chuck would fit my makita they said no. And it has that thread type.
When I removed the chuck from my makita battery drill it was a case of put an allen key, big one, in the chuck and hit it with a dead blow hammer a few times. It unscrewed nicely. Then any 1/2x20 UNF chuck should fit but you could see what it looks like when you get it off.
Oh dear, mine came off pretty reasonably after about 4 hits.The allen key trick was my first attempt. I've also tried using an impact driver. I've really, really beaten on this thing. I understand it's lock tighted and torqued to heck. So I got heat left as a solution but I want it out of the drill for that too so I don't damage the rest of it
Is there a locking screw down inside the chuck?The allen key trick was my first attempt. I've also tried using an impact driver. I've really, really beaten on this thing. I understand it's lock tighted and torqued to heck. So I got heat left as a solution but I want it out of the drill for that too so I don't damage the rest of it
Few weeks ago I rescued and brought back to life this old lather gouge.
Nit had a chance to use it in anger, but work today took me to a site were they do "Pole Lathe" work.
Knowing I would be there at least 3 hours it went for a jolly.
I was allowed to play.
The gouge was not as good as I hoped. But it was explained that I had done a good job putting an edge on it and for a power lathe it would be OK.
But on a Pole lathe they have a different angle on them.
Fun work and a experience.
The faces were "Burnt" on using this.
Is a pole lathe the type operated by foot?
