angellonewolf
- bristol england
Ok got a quad if a mate that's helped me out a few times said I look at it for him
Been sat for 6 years in a barn checked spark and also changed the spark plug after a sonic clean of the carb started and started easy but when you use the throttle it bogs and near dies
Now this unit has 2 tanks one for oil and one for fuel for the moment I'm bypassing the 2 tanks and using only a fuel mix direct in to the carb could this be causing the problem ?
I've done a second clean and refitted and still the same even as the air screw was near fully in it was said from watching a few vids that is was starving of fuel so I've increased the pin on the throttle up a notch but still no difference
There is not much adjustments on the carb so assume there's not much to go wrong but I was going to buy another carb but I can't find the right one here a pic of the actual carb
