DAPPH
as dyslexik as I'm daft
I guess you're right , though it is for industrial use so might be a lot better than the B&Q sold stuff .it wont be the same stuff as 18 years ago.
Great bits of kit the Gems,Got a wee rotavator to prepare the ground for the wife's polytunnel. Excuse the flat tyre. It's old but gold. Test strip in the background.
That particular model always makes me think of the good life.
Had a delve in Pandora's box today - if anyone ever needs a spanner, I'm your man.![]()
The paint covering is very thin, and some was transferring to my gloves as I sorted through them so I suspect I was right about the 'quick blow over'. Anyone ever removed such with citric acid or electrolysis, before I set about this/these processes(s) and waste my time?
Most are Imperial, only spotted a very few Metric among them. At least I'll not be short of claws for my horseshoe crabs......![]()
caustic soda is best for removing paint, ime.
Thanks Paul. I will need to cut em down so I will do the method you described.Thats a piece of euro tooling for use in a pressbrake, if you need to it can be cut quite easily for use in a flypress, only the very tip is hardened so stand it up in the saw and cut all but the last 2 or 3mm then break it off and dress it with a sander, done it many times to use old press tooling in the flypress, the vee block will likely need cutting with a disc though.
A fairly weak solution [for safety/disposal reasons] I suppose?![]()
over the garden fiepit.Today I acquired.
These very nice metal formers .these will make great forming tooling for my flypress. I also aquired something very nice indeed. But you will have to wait until tomorrow for that.View attachment 172754 View attachment 172755 View attachment 172756
Does it also derust [surface stuff] or is it then a case of into the other bath/s after getting rid of the horrible 'shine'....?Last question on this, I promise.........Does it also derust [surface stuff] or is it then a case of into the other bath/s after getting rid of the horrible 'shine'....?
Eat your heart out @knighty
Acquired this new to me mixer today,found it buried in a hedge on a land clearance job. Anyone that wants anything off it let me know before it ends up in mixer heaven.
Bob
I have got to cut them to size . It's a Norton 8 flypress. She got plenty of power.Not so sure a flypress will power tooling that long, not sure of the tonnage of the one I built but it can only handle about 18" of tooling.
Bob
