pressbrake1
A procedure that doesn’t require the poor thing slammed in reverse!You can use the thread dial and half nuts but you still need to reverse, and follow a specific procedure.
thats when it breaks! right?????A procedure that doesn’t require the poor thing slammed in reverse!
My mastiff for example has forward reverse and brake clutchesthats when it breaks! right?????
preferably but if not level with packing pieces till it isyes situating and setting it up will take me a while i need to have a clear out, Do they have to be on dead level ground?
That is a the tumbler reverse. It just reverses the lead screw rotation.
travel left and right of saddle for thread cutting or automatic feedwhat does this enable?
Have a read herei may have to level the base with some concrete
The boxford doesn’t so putting the electric motor in reverse from forward without stopping is cruel
I don't think the Boxford's cabinet adds rigidity to the bed so just sitting fairly level on firm ground would do it.
Yes and just using the stop will mean just coasting to a stop, not so good with the half nuts engaged!You'd always have a stop position between forward and reverse.
A VFD, on the other hand, allows you to switch straight between forward and reverse.
Not with either VFD I have. The VFD uses the ramp configuration to slow to a stop and then accelerate in reverse.
And yes, going hard into reverse could cause the chuck to unscrew, unless you have a means of clamping it to the spindle.
Mine is on machine feet at the moment but once I'm sure it's staying put il probably do the same.On mine I just epoxies some 12mm thread bar into the floor and put a nut and washer each side of the mounting holes in the cabinet.
I could then adjust / twist it to get erything levels / solid.
Worked a treat and absolutely no rock or movement and a really solid base for adjusting the bed.
The whole thing is so light that in reality gravity isn't much help
Yahoo has a Boxford users group.
