Curiousgeorge
- Wales
Hi all.
A company I work for makes cylindrical pressure vessels that are essentially a cold rolled piece of stainless steel that is then seam welded and threaded bosses TIG welded in the walls of the vessel (sometimes near the ends so can disfigure the shape). Then the vessels are put in a machine where the operator then adds a dished end to either side and uses a belt-like steel apparatus to tighten the vessel's ends to, theoretically, make the vessel and dished ends fit perfectly so the operator can then tack the dished ends to the vessel before a machine then welds each seam.
However, in reality, the vessel and dished ends rarely meet up so after the belt-like apparatus is tightened and the operator tacks around the dished end, there is a gap between the seam welded part of the vessel and the dished end (photos would be useful here). Then the operator uses a hammer to force the raised part in and then aims to fill the gap with tacks.
Obviously this is not ideal and in a perfect world, both ends would meet up each and every time. So I am trying to get to the bottom of this. I am thinking that the first thing I need to do is find out if there is a variance in diameter in the vessels after they have been rolled and the bosses tacked in.
Please can I ask what is the best way to do this? Some have suggested a tape measure but I'm not confident that the starting point and end point will always be through the centre of the vessel so are there any tools out there to measure the 'circularity' of a circle?
Thanks all, I'd love to solve this issue.
