I thought the nasty stuff was just due to using air rather than a helium/argon mix?It cuts through aluminium easily enough.
It can leave a nasty kerf on the back side which can be hard to remove.
Can also need quite a bit of clean up before welding the alloy compared to some other cutting methods .
Depends what you are doing as to weather it's the best tool for the job?
was that just with air?Cut Alu all the time on the plasma, personally I have no probs with dross on the back really. Edges clean up very quickly with a quick skim over with the flap disk and no issues with Mig or Tig welding for me.
Today I cut quite a few bits of Alu some of which I welded, below is one of the things I did today.
Oh that is a definite, the 12mm above was actually cut too slow as I had been having issues with the plasma and although I had them sorted by the time I cut that particular one I was still a bit too scared to up the cut speed as a chunk of 12mm plate is, although not massively expensive, not something I wanted to screw up. I think I was only feeding about 600mm/min in that vid, should really have been about the 1000. Due to that there was a lot more dross than I get now, really the only bits I get it at now are where it goes over the slats on the table. I keep meaning to order a sheet of 3mm steel and cut some slats out of it with small points so that the majority of the material is above the slats.I'm hand cutting with mine , I expect travel speed and other operator factors have something to do with my problems!
My plasma is a Cut 50, but with a better torch (thanks Hugh) and does well on steel. Would different types of ally make a difference?
