Are you planning to run both lathes at the same time.I have a Boost Energy systems 4KW Rotary phase converter, I am considering another lathe which means Im gona need more power. Is it possible to upgrade the one I have by putting a larger motor in it or is it more complex than that ?
Yep, its looking that way............. more ££££££££££s :-(New one.![]()
you could build your own?
(I've got a couple of big 3 phase motors left over I'd happily send you one for scrap price)
I may have some large 3 phase motors available
it depends how they are designed.some manufacturers will limit everything to its rated output.some have a few common ratings to speed up production and reduce number of stocked parts
that's cable cross section,mcb'c,contactors,mains switch etc
then you have the transformer/auto transformer kva rating
then cap sizes to start and balance the motor
its not a simple change
