Looking to buy just one 50mm core drill not a set. What brand is decent?
all the prefab conctete garage panels have reinforcement rods through themi'm after a core drill to cut a single 5" diameter hole in a prefab concrete panel. (the thin, unreinforced, infill, not the "frame")
can i take the same recomendations as the OP?
that's hilti . well over priced but good quality. having said that the amount they made of the job well compensated for the outlayAnyone else thinking Hatton Garden?![]()
ive already removed/smashed one of the panels to fit a side door.Yep they at least have wire in them. 4 or 5mm smooth wire mesh or thereabouts usually.
its old - 40-50 years at a guess.Aah, well that's unusual.
only ever heard of the bosch ones on that listJust been looking at this short review on core drills.
Anything appeal ?
The thin walled 5" drill bits will do that but you absolutely must use water coolant or you'll cook the diamond segments.
Ebay has this:
https://www.ebay.co.uk/itm/127mm-x-165mm-NEW-Dry-Diamond-Core-Drill/233135466491
