Hello everyone!
Some comments would be appreciated on my plans for welding table so I can have some corrections!
Table will be 2000x1300x6mm steel plate on top of construction out of 60x40x3,2 rectangular tubes. Legs will be 50x50x5 (six legs) and height 500mm
Bottom view:
Total weight is around 200kg, plate alone is 125kg. Weight on top will be no more than 400kg (off-road buggy) evenly on entire surface.
I will add bolts on legs so i can level the table. Steel plate will sit free on construction so i can level the plate so it is perfectly horizontal.
Any comments? Should i use any thicker material? Do i need more legs for support in the middle?
Bottom view:
, it really depends what your going to be doing on there
One thing i would say is make sure you round the corners on the plate
). I want to keep my steel bill as low as i can, 50x50x5 angle is because it is lighter and i can put a clamp all around the table as far as 150mm in. I don't know yet if I will weld table top or bolt it on frame, dependently on how straight I will manage to weld bottom structure. If it wont be level i will bolt top down so I can put some spacers to level it, to be perfectly horizontal.
I was wondering where he got your man as well
Here's the 'ittle fella for you'!
