Jlg
- Cumbria
can anyone machine me one of these
And cut me a 13t a 16t and a 20t 14dp gears
I might have forgot that partPlease?![]()
Worst case I'll have to buy the gears but I at the very least need the gear plate machinedCutting the gears is a lot of work.
What tooth count are the gears and would you part with themwouldnt the ml7 tumble reverse do you like it does on the myford ml 1-4 machines
a drumond tumble reverse
i found an adaption using an ml7tumble reverse gear for a myford ml 1-4 machine was going to do mine at the time before i sold it
still have the tumble reverse gear though
Is that first picture a for sale picture that you found or just a pictureand for your info parts did exist for them so done some digging for you
from the lathes site
http://www.lathes.co.uk/drummondaccessories/
I saw that 16 tooth but I didn't know if it was the right dpive found a 16 tooth gear via something else
https://www.ebay.co.uk/itm/New-Myfo...item2cdfb65c72:g:O~0AAOSwF~hb9Udw:rk:141:pf:0
https://www.ebay.co.uk/itm/16-Tooth...item1c841d3802:g:FvQAAOSwTuJYwryr:rk:175:pf:0
that would leave the 13 tooth gear to be found ive found a 12 tooth gear instead but not between
https://www.ebay.co.uk/itm/Myford-1...item19e23a672c:g:yzwAAMXQAF5RiIuO:rk:190:pf:0
