I'm getting a file of someone laterI can't help you with printing. But a drawing of the part you're after at very least would help.
You need to make it public to view.It's basically the parts to make this https://www.mig-welding.co.uk/forum/attachments/e300afa1-e18a-4230-9f79-24cdbcb75416-png.167434/
Quality wise it going to be used to get a casting made
I'm not too consernd with shrinking as the print file is going too be oversized to be machined downYou will need to address shrinkage in the primary part printing and also the casting further down the line. So say the part was printed in a plastic that shrinks after printing 0.5% this is not the end size you need because once cast the shrinkage in metal may be 2%. This needs to be addressed by scaling in the initial printing stage.
Ah thats a different kettle of fish. The casting should be ok as you will be able to adjust the spindle centers when you bore them to size.The strength was just in case tha casting dose not work I can use the printed part
