All decent cars used to have "brass" nuts, Always around a nut and a half long.
I have around 200 of these to help with manifold swaps. Make life so much easier if need to remove again
You need an electrolyte to get galvanic corrosion.
Can't see there being much in an exhaust manifold unless you are planing to regularly ford estuaries or the like.
I've used A4 stainless nuts on mild steel exhaust studs and they have always come apart without issue.
The real bonus is the stainless nuts don't rust away.
I do use brass if i have them though.
Accelerated by heat.road salt plus moisture
Seriously?
How long is the moisture going to last on an exhaust manifold.
Sure it's a theoretical risk but it wouldn't keep me up at night worrying.
Any sensible person would put them together with a bit of copaslip or the like (no matter what nuts and bolts are used) which would also exclude any moisture.
It has worked well for me.
Seriously?
Seriously?
theoretically thats even worse ;-)
I use a really high temp stuff thats known in the state of california to kill you . .works well. As an antiseize that is. Not been very good at the other so far!
But I use brass or "copper" nuts too.
absolutely serious.......and thats only from the outsideSeriously?
