yesterday I broke down in my car as I had a flat car battery. I called out one of the recovery companies and when they arrived I told them of the issue. I'd driven for 30 minutes to get there, I was there for a couple of hours with nothing electrical switched on and there wasn't even enough power to crank it over a a couple of times.
The recovery guy then asked if I wanted the battery testing and to be jump started. my reply was that the battery was fine when I set off so it should be fine now, but you can do an alternator test. with an output of 12.7V it looks like my diagnosis was right and it was the alternator that had gone. (really annoying as is too much voltage to illuminate the battery warning light)
so back to the reason for my post, how can you test if a dead car battery needs replacing, my way of thinking would be that you can't as there is nothing to test and its just a ploy to get me to buy a new battery from them.......with several different sized ones in their van.
I do know that if I cycle the battery that was dead it'll be fine for while longer.
