redwine300
Silly Rabbit
Hello Again All....Fabricating inner wheel arch section and after welding and tweaking to fit, i have found cracks along the weld. What can i do to prevent this????
Hey RW. Looks like the crack is the original metal, and your weld didn't penetrate through the join. You've ground off the weld, hence you can see the joint again.
That's all assuming I'm looking at a crack in that photo.. i'm not too sure![]()
i can't see it....
practise with welder and airbrush needed i think...
Is there a fundamental reason for the cracks? eg low grade material/wire etc' or could it be down to poor welding on my behalf?
Redwine, it's either the reason I gave you earlier. Or your welds are just crap.
Don't overdo it with the sugar coating Si![]()
Sorry RS, just had a little moment there....
