well I have used mailtraq for over 10 years but it was set up by the author. I have learnt quite a bit over the time so i can add users and recover lost emails etc but repair afx files etc BUT mailtraq has come to the end of its life and the support forums have been taken down.Yup. What's the problem?
The new host ought to supply a decent set of instructions online, detailing setups with the better known email clients. Why not use webmail, and use IMAP for the client? That way, the web version ofthe mailbox can be synchronised with the client version. Main issues are usually port numbering and authentication settings.
when you say use webmail coulkd you expand a bit more..I can use webmail in Cpanel to read but I need to sort mail to get it into forte agent etc.The new host ought to supply a decent set of instructions online, detailing setups with the better known email clients. Why not use webmail, and use IMAP for the client? That way, the web version ofthe mailbox can be synchronised with the client version. Main issues are usually port numbering and authentication settings.
Ok I am not actually as confused as it might look. lolYou might be a bit confused
If you have set the individual email accounts up on a guru server then you don't need hmailserver as that is the type of email program that someone like guru might use to set up the individual email accounts. Unless you are trying to avoid using the guru email accounts and trying to do it all yourself
Gmail can be used to collect emails from pop email accounts as an alternative to using a client program such as outlook or thunderbird
Pop and IMAP are protocols that the client program would use to collect the incoming emails from the aerver
how do I get a pop3 connection without security???Ssl is not tls.
I'd start by just getting a pop3 or imap connection without any security first then turn on the security later.
Thats how it was on my old hosts...but it does not work on GURU.untick the SSL and use port 110
well the problem is with all the mail clients and viewers I have tried. It looks like mailtraq is also dead in the water as prior to receiving your reply I had indeed tried thunderbird and it connected instantly. So you were spot on.I think the problem is potentially forte agent, try accessing the account from thunderbird or some other email client but remember to tick the box to leave the email on the server if you want to give yourself future options
