I recently acquired 2 sip compressors.
I was servicing the 50l one & while I had the cylinder head off I decided to check how close the figures were for the cfm & fad that were printed on the plate.
The figures I calculated were not what I expected, can I see what you get to see if I am I going mad?
The bore of each piston measured at 60mm, the stroke was 40mm, there are 2 pistons that each go up & down once per revolution. On no load the pump turns at 1163rpm.
I have had the head off & cleaned a load of gunk from the valves, did some porting plus cleaned an air filter that was caked solid so it should be much improved!
