Following this since I've got an '8KW' one on order.
@fizzy Chinese heater specs/link/price please? I have a bathroom infra-red one above the 'main' bench for when I'm playing at it, but it doesn't do much for the other corners when I'm there.
Do you have any problems with condensation, i imagine paraffin as a burning fuel would give off quite a bit of moisture?Installation is quite a faff. If you have a big draughty area I would use one of these.
Its always a gamble with direct combustion, gas is terrible for condensation, red diesel appears to the the best i have found so far.
Fitted a couple of these to boats a short while back. First one worked great, well for a week or so
Second one we couldn't get to fire at all, it was the simple controller and it was just showing 2 LEDs which we eventually found out was over voltage. I measured the voltage and it was fine, around the 26/27v mark. So that was when I wondered if it was a 12v circuit board inside even though it had been sold as 24v and had a 24v sticker on it. Hooked it up to 12v and it was much happier, the control worked as it should regarding the LED display but the pump was hardly pulsing so obviously it was a 24v pump and a 12v heater. Skipper had enough of it and skipped it and bought a Webasto heater which fortunately bolted to the same brackets I had made and exhaust and inlet sizes were the same so they didn't need altered either![]()
Think it is a bit like anything cheap from China, you can get ones that are dead out the box, ones that last a few weeks/months or ones that run for years.
Most of the boats here have Webasto or Eberspacher and they last a long long time, in fact I don't even recall of any packing up completely, I think a few have had new plugs and a clean out but none have actually died as far as I am aware. They do cost 6 to 8x more than the Chinese ones though.
I could find out for certain tomorrow though as I will be up working on one of the Cats I am currently fitting out and they have just fitted a Webasto to the one I fitted out last year.
This is the one I have just bought
With the 24V feed and diesel as the fuel I'll pass. Also at that price I'll come back into the house if it gets too cold in the shed.
No it is a 12v feed.Sorry Vince, I misunderstood, I assumed it was electricWith the 24V feed and diesel as the fuel I'll pass. Also at that price I'll come back into the house if it gets too cold in the shed.
Surely as a true Scotsman running costs at 1/3 that of electric must be of interest!
Thanks, got the supply current wrong too!![]()
But that aside [I do have a 12V supply I could use], the carting storing diesel from 14 miles away would be a right pain in the testes, so I'll say...."I'm out"![]()
