Bryan Williams
- Manchester England
Replacing dead bathroom bulb, the dead on was pushed into the fitting flush with the outer glass, I removed it with difficulty only by tilting it to get It past two little rivets.
Cannot get the new bulb to go past the rivets , my son thinks its not supposed to push fully in against the glass but rather sit above the rivets on a ledge, maybe to let heat out as this leaves gaps around the rim of the bulb.
Any thoughts before I get a bigger hammer?
you should not need to remove the fitting to change the bulbs
