Had this old 125mm ceramic sanding disc lying around in the shed for about 4 years, so thought I would finally give it a try as I am making a belt linisher and needed to get rid of some mill scale, paint and rust off the steel I am using to make it as it used to be an old weight exercise stand. This stand has been out in the elements for about 4-5 years and not being used so re-purposing the steel.
After using this disk for the last two days I am quite impressed in how it is holding up and how it sands with minimal clogging. Been using it on everything including grinding down fresh and hot new welds and all that other crud.
Looks like I will be getting some more of these as they are lasting much much longer and sand way better than the other sanding discs I have been using.
