bigegg
- Leeds, West Yorkshire
I put a new roof on my 20x10ft garage over the summer:
it slopes the long way at an angle of about 20:1.
I used good condition, 2nd hand metal sheets with proper roof screws, on new joists above the old (plywood) roof.
it's still leaking!!!
the roof sheets are overlapped about 8 inches, but I didn't use any sort of sealant on the joints.
they are tight, and flat though - no huge gaps.
I'm not sure if I'm getting run back under the joints, or water is getting through the screw holes.
im rhinking of buying a couple of gallons of "black jack" damp proofing paint and putting on a couple of coats to build up to about 3mm thickness, or even some tar and applying it hot?
is this likely to work? or should I take the roof up and seal the joints as well?
waiting until next year isn't an option, so need something that will work now - even if it means using a flame gun to heat up the roof.
obviously I'll pick a dry day!
I haven't added to the other thread, because that's more about bad access and foam.
I have easy access.
I have easy access.
