cemkarakurt
I have tig welder buy from friend was new for very cheap price £100 it is dc inverter 180 amp tig mma as you can look at the picture
the problem is whatever I do setting is not effective welding. Before the problem happen when I put the welder to 80-110 peak current and 35-45 base current they will do the job but now even I put on to max I got minimum setting power. Pulse is not working at all frequency is not working welder only work on minimum setting even I put to max setting or varies setting I got same result
so any one have idea Troubleshooting point. where can I look at it I have checked the inside is well no fuse or adhere thing wrong argon gas full 130bar flow meter is 15 psi min.
