I notice some of you mention using them to heat a shed. How much smoke do these things kick out once going, it doesn't look like much, how would it be in a workshop, too much smoke?
They kick none out apear as smokeless also its a learning curve with them
JUst like any new wood stove
Greenhouse. could you expand a little please??no smoke at all, once hot.
it does have to have a chimberly to outside, though.
if you pass the outlet through (not into!) a greenhouse/earth bank/flowerbed, the output can be almost undetectable. (just a bit of water vapour)
and you'll have a frostfree growing area.
build a rocket stove half buried at one end of the greenhouse. have an extended flue running underground to heat the soil.Greenhouse. could you expand a little please??
How is it likely to be inside a 20ft shipping container with a door open without a chimney? Would that be enough to get rid of any fumes/ bad gasses?
Excuse what probably seem like daft questions but I have limited knowledge on stoves, gasses and ventilation. Probably seems daft to heat a place with an open door but I'm in and out all day so the door is usually open anyway and I'm not keen on cutting a hole for a chimney through the side/roof of the container at risk of it affecting any future resale value.
An electric heater would be the solution but I'm off grid and don't have the genny on for most of the day. I have a propane space heater but again it's the electric situation and the cost and moisture they pump out, looking for a good cheap solution and a rocket stove seems ideal.
basicallyThanks for the advice it's very much appreciated.
The door is more ajar all day than fully open so some heat would be kept in but limited. I have a couple of meters of the flexible flue that I salvaged a while ago thinking it may come in useful.
I think the option of a temporary flue pipe that is flexible that I can shove out of the door in the morning is the way to go, keeping it up at roof level out of the way. Not too worried about the smell of the burnt wood.
Maybe over simplifying things here but is it just a case of connecting the flue at the exhaust of the stove (where a pan or kettle would go)?
That way, you could even close one half of the door(s).
