sako243
- My mansion in Wales
So courtesy of @8ob I've upgraded from one and a half pillar drills to a few more, oops.
I must say they're a well built bit of kit, and the table is something else. I finally found some time this weekend to struggle to get the table into the shed. I think our estimate of quarter of a tonne was a bit off. Apparently the Progress 2g on the floor is 178kg on its own, and I can believe it.
To put the size in perspective that's an ML7 that had to be relocated.
Plan is to wire in at least one of them to the phase converter so it's usable and then refurbish another one in turn. May move on one of the Progress 1s as two are excessive, three might be considered obscene.
Couple of question since searches haven't brought up much (related to the 2g).
- Where can I source a replacement quill return spring, this one on removal has broken in a couple of places.
- How do you remove the gear change handle (doesn't appear to be any roll pins etc) and one of the cap head screw holding on the housing is blocked by the handle.
