winchman
- Merseyside
Run a length of hose from the gas taps into a container of very soapy water, you get streams of very flammable bubbles. I vividly remember watching flame roll over the ceiling!
Fits like a glove.It's a bit battered but you cant knock it for the price..
yup working in a school and squirted the apprentice with oneI never set fire to anything but I did put the bunsen burner hose on the water tap. It fires a tiny jet of water a very long way![]()
he saw the funny side of it and got his own back on me
Do not fill 4/4 full of water and 1/2 lt of washing up liquid.
DO NOT fail to notice Mrs TYA looking at you with "That look"
Do not do this.
Do not get a 5 gallon brewing bucket.
Do not fill 3/4 full of water and 1/2 lt of washing up liquid.
Do not place in bucket OA torch, with gas flowing.
Do not add food dye.
Do not let the column of bubbles rise up.
Do not have Mini Me and her friend in the upper bedroom window with a lighter
Do not have her light said lighter.
Do not watch the big smoke ring rise above house.
Since you didn't do any of this can you please post the video recording of it on the mig-welding forum for ourDo not do this.
Since you didn't do any of this can you please post the video recording of it on the mig-welding forum for ourentertainmenteducation so we aren't tempted to not do it ourselves.
Of course if you didn't record it the first time you're only running the risk of some of us untrained idiots trying to replicate such a dangerous feat, so in the best interests of H&S it would be better if you could just post a video showing just how dangerous it is so none of us are tempted to try it at home.
It was fun lighting the gas taps![]()
Back on the 13th Oct See Post No. 11442. I acquired a Marples Mitre clamp.
On the surface it didn't look to bad.
It wasn't to bad.
A good clean and a paint strip in Hot caustic solution to remove the bad paint job.
It showed that one of the C/sunk mounting hole had bean filled in with filler, no reason why as far as I could see. Unless it was to take a M6 C/sunk screw. But why just do one.
So I asked a friend to TIG it full and machine a new C/sunk hole.
Here it is all done.
Is that a straightforward mitre clamp, or is it some sort of mitre cutting guide? Looks like it has some sort of adjustable stops to set the max depth of cut.
