Depends entirely on what you’ve got.
Main line rail is a high carbon steel. A bit crack sensitive but a bit of pre heat and a few stitches should see it stuck down fine.
Crossing section rail is a high manganese stainless steel usually something like a 307 grade. In this case you’d probably be best using a stainless consumable 312 would be best but for slapping it on a bench your 316 would do. Again crack sensitive but to excess heat. Weld it as cool as possible.
High Mn rail was designed to work harden so if you’ve got a lump of that expect it to be very hard.
I’m gonna say cost but cannot be sure. Logically part of a crossing has a long tapered nose and long tapered switching blades. These areas are gonna be most vulnerable to wear so an expensive work hardening material makes sense. They are manufactured via a casting process and dropped into the line. Main line does wear and goes under regular repair but probably not to the same extreme as a crossing so expensive casting materials are probably not justified for miles and miles of mainline.Why do they use different materials for main line and crossing section?
Good job it's 312 i have, for some reasons I thought 316312 will be a good bet
Wheel burns from trains wheel spinning at start up are really all the main line suffers from but crossings take a real battering and those blades can get pretty thin.
Two totally different welding/cladding procedures for addressing them as well. Main line is 400°c preheat and maintain through welding hot.
Crossing is zero preheat with a 100°c max inter pass temp. Both can quite easily crack if the temp isn’t monitored properly.
I only know this stuff through doing some work with companies that look after the rails. I’ve seen where they manufacture and where they repair the crossings in house and on the line.
Tram rails are all high manganese 307 stainless steel. Because the tram wheels hook over the rail and a lot of them are curves they wear the edges right out. I’ve seen those repaired too. That’s not fun. Because they are set in this rubber type stuff you really do have to watch your heat input. Bit of info there for ya.
