chunkolini
celebrity artiste
- Swansea
How water went up the spout a couple of weeks ago, cycling between hot and cold.
Engineer came out and changed a valve, charged me £150 and it did not solve it. Possibly new boiler needed?
Then a radiator was refitted and leaked so we drained the system and sorted that out. Plumber charged £50 to fit new rad which seemed reasonable.
Now after refilling the system there is a leak from a valve on the bottom of the boiler. Quyite a serious leak. It looks like an inline valve. Heating blokey says he never touched it.
Any ideas what I can do with it. Turn the valve a few degrees? it is loose to the touch.
Picture in a few minutes
) and a standard 22mm ballofix valve fitted on the vertical pipe below to keep you going.
