First pass root no weaving, second pass it's either a weave or stringers dependant on wps. Often weave isn't allowed.
Americans seem to love to weave everything, not sure why but there's better ways if doing things.
Even worse than that clown ChuckE2009...How about this technique? Quick dash ahead to let the weld pool solidify and then back to the pool...
As in this vid...
It seems to be giving me slightly better results on first try.
Cheers
Adri
@Brad93
On Jodie Colier vids on YouTube he says he always uses a high Arc Force setting as he holds a tight arc. Why did you suggest setting AF to 0?
Cheers
Adri
Some progress today...when I compare to last week it's really coming on but still looks like there's a fair way to go. On the flat it's all hunky dory... the troublesome stuff is uphill fillets...
Well I've worked through a box of esab 450mm 7018s and now have a box of bohler 7018s on the way. these new ones are shorter so should be easier to handle.
Adri
@Arclikeharrypotter
Your root pass in the photo. Is that with a 3.2 or 2.5 mm electrode?
Cheers
Adri
